Welcome Guest Search | Active Topics | Members | Log In | Register
Airfix E-Boat - Finished Options
35th-scale
Posted: Monday, November 07, 2011 11:17:17 AM
Rank: Jedi Master
Groups: Member
Started this last night...
First, a stamp on the inside of the hull indicates the molds at least are from 1975! And I'm thinking mine must be an early kit...the moldings are very crisp with very little flash. Thanks Roy! I've recently done other old Airfix boats and wore out a set of files. (OK, slight exageration)
Just put the hull together so far. This photo doesn't show it, but there will be no filling or sanding required at the bow and minimal along the seam between upper & lower hull. (Lower hull can be omitted if doing a water-line kit)
The deck is not actually attached yet
dermo245
Posted: Tuesday, November 08, 2011 5:54:33 PM
Rank: Step away from the computer!
Groups: Member
Very nice....and very big!
Will follow with interest.
On the bench:
1/72 Airfix Gazelle conversion
1/72 Revell F-16A
1/72 Revell Ec-135
Completed Builds
In the pipeline
1/72 Revell F-14D Tomcat diorama
35th-scale
Posted: Wednesday, November 09, 2011 12:19:41 PM
Rank: Jedi Master
Groups: Member
Just under 18inchs long Dermot.
Hull and deck put together and some of the major sub assemblies:
Torpedo tube fittings/doors seem a bit bulky, but all going together very well. The front doors actually work, the rear loading door had to be glued in place. The 2 spare torpedos actually fit into the tubes: I might built it with one coming out of the tube...
I'm going to have to be very careful with painting as the windows/skylights are in place internally. I don't want to knock any out with masking...
john 64
Posted: Wednesday, November 09, 2011 7:20:15 PM
Rank: Member
Groups: Member
Super model , i wish it was possible to buy one missed last re-issue of the model , not easy to source one i have tried , looking forward to your progress with it .
35th-scale
Posted: Thursday, November 10, 2011 9:40:33 AM
Rank: Jedi Master
Groups: Member
Thanks John. It is an oldie but a goodie! I'd been looking for one for ages too and was lucky to pick one up from a member here. Did I mention it was just €12 :-) but without instructions. They were easy to source elsewhere though. The kit does show up on ebay regularily but at crazy prices
john 64
Posted: Thursday, November 10, 2011 9:57:26 AM
Rank: Member
Groups: Member
amasingly sourced one on hornbyshop last nite looking for $83 ? maybe worth it but i will see.
Wild Weasel
Posted: Thursday, November 10, 2011 1:27:35 PM
Rank: Jedi Knight modeller
Groups: Member
Lads i see Kingkit in the uk have one on their list for 24.99 sterling do your search on website under ships
Donncha
Remember - If you spot someone in trouble at sea, inland lakes and rivers, on the cliffs or coast, even if you 'think' that someone may be in trouble , dial 112 or 999 and ask for the Coast Guard. If you are in trouble at sea, call on VHF Channel 16, MF 2182 KHz or use DSC.
35th-scale
Posted: Sunday, December 04, 2011 4:30:25 PM
Rank: Jedi Master
Groups: Member
Been a while since I gave an update and unfortunatly progress has been slow...
Main deck painted and woking on some of the sub-assemblies:
With the bits dry-fitted on deck:
Considering it's age though it's going together quite well. Paints are Humbrol enamels as listed in the instructions but I'm not too sure they look right. Most pics I've seen have a darker deck and lighter sides....
35th-scale
Posted: Tuesday, December 27, 2011 8:57:17 AM
Rank: Jedi Master
Groups: Member
I did finally find time over the few days to start on the hull of this though....it's been sitting idle in the run up to Christmas.
Portholes are still masked and a bit of tidy-up to be done around the edges but basically ready to start adding all the wee bits.
Posted: Tuesday, December 27, 2011 9:35:45 AM
Rank: Administration
Groups: Moderators
Looking good, it's a handy boat and good size too, I'd say
35th-scale
Posted: Tuesday, December 27, 2011 11:21:28 AM
Rank: Jedi Master
Groups: Member
Thanks Filip,
About 18 inchs long which is a nice size. Some of the finer detail bits I suspect are out of scale and quite a few have seam lines and ejector pin marks that need dealing with but all-in-all it's a nice kit, but time consuming which is in short supply these days.
Hopefully I'll get to post some close-up detail pics tonight
dermo245
Posted: Tuesday, December 27, 2011 5:31:16 PM
Groups: Member
That's coming along nicely and will look good beside your other S-Boat!
Looking forward to more pics too.
On the bench:
1/72 Revell F-16A
1/72 Revell Ec-135
Completed Builds
In the pipeline
35th-scale
Posted: Wednesday, December 28, 2011 12:46:59 AM
Rank: Jedi Master
Groups: Member
Some details shots:
It's amazing how many flaws show up in a photograph. Maybe it's just my eyesight|
Anyway, your comments are always welcomed
Enjoy
35th-scale
Posted: Tuesday, January 03, 2012 3:19:22 AM
Rank: Jedi Master
Groups: Member
Just got a nice long session at the bench with a Tamiya weathering set.....
Still lots to do.
AlcatrazLogan
Posted: Tuesday, January 03, 2012 1:07:12 PM
Rank: Jedi Master
Groups: Member
Nice work with the weathering set, it's very well blended I have to say.
chiefwiggum
Posted: Tuesday, January 03, 2012 6:56:52 PM
Groups: Member
look super sean...what lenght is it..looks a good size... a figure manning that machine gun would look the business
great work well done
Barry Evans
35th-scale
Posted: Tuesday, January 03, 2012 8:01:21 PM
Rank: Jedi Master
Groups: Member
Thanks Gents
It's about 18inches long. Not sure about adding the figures...they're not great
Posted: Tuesday, January 03, 2012 11:45:29 PM
Rank: Jedi Master
Groups: Member
That's a great bit of work....!! Super
I do hope it will be entered into the ships category at the next Irish Nationals in Shannon in September! (IMHO, it is sure to be a winner.)
If you can, can you bring it along to one of the next Dublin Chapter meetings, as I'm sure we would all love to see it in the flesh.
Congrats on a fine piece of modelling! Applause
"To boldly go.....wherever"
Posted: Wednesday, January 04, 2012 9:06:05 AM
Rank: Jedi Master
Groups: Member
That's excellent looking Sean, well done! Those Tamiya kits are great for adding rust here and there, aren't they?
And, reading down through the thread, I'd say it's about 18 inches long, right? ROFL
Revell 1:72 F-16B
Completed builds
Coming attractions -
Eduard 1:48 Bf 110 G-4
Academy 1:72 F-22a Raptor
Tamiya 1:35 T-55a
Moebius 1:128 Seaview
35th-scale
Posted: Wednesday, January 04, 2012 9:38:52 AM
Rank: Jedi Master
Groups: Member
Thanks for the comments guys. I will bring it along to the next meeting I manage to attend....just not sure when that will be. Not sure about the Nationals though: I've seen how those judges crawl all over everythnig ;-) but I will keep the instructions this time just in case.
The Tamiya weathering set is great. I have had a sand one for ages but the new one with rust and metalics is the buisness.
And I'd estimate the length at closer to 45.7sm Jason :-)
Users browsing this topic
Guest
Forum Jump
You cannot post new topics in this forum.
You cannot reply to topics in this forum.
You cannot delete your posts in this forum.
You cannot edit your posts in this forum.
You cannot create polls in this forum.
You cannot vote in polls in this forum.
Main Forum RSS : RSS
SoClean Theme Created by Jaben Cargman (Tiny Gecko)
Powered by Yet Another Forum.net version 1.9.1.7 (NET v2.0) - 11/20/2007
Copyright © 2003-2006 Yet Another Forum.net. All rights reserved.
This page was generated in 0.280 seconds.
