Joined: 11/29/2010 Posts: 352 Points: 1,071 Location: Kildare
Nearly there.... Props, rudders, rigging and stanchions added. Just need to add the "rope" along the railings...   One more session should see it complete. Thanks for watching Sean
Cheers Sean
Joined: 9/7/2008 Posts: 922 Points: 1,978 Location: Co. Limerick
Getting there... hopefully you'll replace that 'poitically correct' flag with some proper one over time, it really stands out on the otherwise nice model.
Rank: Member Groups: Member
Joined: 9/10/2011 Posts: 10 Points: -67 Location: cork city
35th-scale wrote:Nearly there.... Props, rudders, rigging and stanchions added. Just need to add the "rope" along the railings...   One more session should see it complete. Thanks for watching Sean super job you made of it, i would say you enjoyed building it, well done, John.
Thanks John and yes I did enjoy it. Very pleased with how it turned out.
Thanks Filip. Heah I really should fix up the flag. I don't supose anyone has 2 spare swastika decals that measure about 5mm sq?
Cheers Sean
Cheers Sean
Try to search for Kriegsmarine flag on uncle Gooogle, save yourself a hassle and get printed flag off some online shop
Joined: 2/9/2011 Posts: 496 Points: 1,403 Location: Naas
Hi Sean, If you're stuck, I have a 1/144 - 1/72 Swastika Decal Sheet, which has numerous sizes. I got it to see if I could adjust the Flag on my 1:144 U-Boat. The smallest Swastikas are about 2mm square, so I should easily have something in the size you want. I could bring the sheet to the next Dublin Meeting and we can find you a few that should fit? Let me know... J. On the bench - Revell 1:72 F-16B
Completed builds Click here
Coming attractions - Eduard 1:48 Bf 110 G-4 Academy 1:72 F-22a Raptor Tamiya 1:35 T-55a Moebius 1:128 Seaview
 Rank: Jedi Knight modeller Groups: Member
Joined: 1/7/2010 Posts: 128 Points: 287 Location: dublin
nice work sean, your a dab hand at these boats, good job.
well done for posting pics
alan.
Thanks Jason I might take you up on that but not sure yet if I'll make the meeting next week.
Thanks Alan....practice makes nearly perfect!
Spent last night putting on the railings with threat....a laborious job! Just one bit left and it's the bit I'm actually most afraid of. It needs a pin-wash along the line down the length of the hull: above, below and in the groove....and I never get a wash to come out right!
Cheers Sean
Wash is easy, a small blob of oil paint/s of required colour mixed in white spirit to make it very watery and transparent liquid. You can alway add oil if it's not opaque enough... Then run it along the ridge with the help of 000 brush. If it's too transparent add another layer, if it's too opaque blend it in with clean brush dipped in white spirit. Nothing to be affraid of, what could happen?
Hopefully I got it right! Look OK to me....but then I'm biased :-) Anyway folks, may I present my completed E-Boat for your viewing pleasure:       Thanks for all the support, encouragement and advise. It was/is appreciated. Cheers Sean
Cheers Sean
It looks good to me. And them two side by side - nice.
Thanks Filip
Cheers Sean
Joined: 10/27/2011 Posts: 156 Points: 468 Location: Co. Dublin
That's turned out really nice Sean - weathering looks spot on. Great to see them side by side too. Cheers, Dermot On the bench:1/72 Airfix Gazelle conversion 1/72 Revell F-16A 1/72 Revell Ec-135 Completed BuildsIn the pipeline1/72 Revell F-14D Tomcat diorama
Thanks Dermot
Cheers Sean
